| FS: afterburner Headers NIB | |
| Subject: FS: afterburner Headers NIB Mon Aug 30, 2010 6:47 pm | |
| afterburners headers un-coated BRAND NEW IN BOX with percy gaskets arp bolts
$125 come get it NOW!!!!!!!!!!!!!!!!!!!
Last edited by BoSStonsSS on Tue Sep 14, 2010 11:15 pm; edited 1 time in total | |
Waldo617
Posts : 194 Join date : 2010-03-20 Age : 35 Location : Milton
| Subject: Re: FS: afterburner Headers NIB Wed Sep 08, 2010 4:00 pm | |
| any pictures? do they have all the "smog" connections so that if installed on a 1996 it will pass inspection in MA? | |
| Subject: Re: FS: afterburner Headers NIB Wed Sep 08, 2010 4:08 pm | |
| No headers will pass inspection in Mass. It's an automatic fail on visual since it's a "modification to original exhaust/emissions equipment" If your place doesn't do a full visual then you have a better chance. Not to mention to run these headers you need to make special hookup pipes which would have the front o2's mounted in them. Not a plug and play operation if you want to pass an inspection | |
Waldo617
| Subject: Re: FS: afterburner Headers NIB Wed Sep 08, 2010 6:02 pm | |
| Mass laws are so stupid...in florida if all of your lites and your horn works you are good to go... | |
| Subject: Re: FS: afterburner Headers NIB Wed Sep 08, 2010 6:13 pm | |
| What Brad was actually trying to say was that those fit these cars great and with a set of reducers with o2 bungs in them and some quick fab work to hook it up to the pipes and you've got a decent set of headers installed for a few hundred bucks. | |
| Subject: Re: FS: afterburner Headers NIB Wed Sep 08, 2010 11:37 pm | |
| Actually what I was trying to say is that it's not a plug and play operation that someone should expect to work perfectly out of the box. But if you want a nice performance upgrade then these are the best headers you'll ever get. Just get reducers with the o2 bungs and then find a place that can make the hookup pipes that run from the reducers to the cats. And hope the inspection guy doesn't look too closely. Remember that Crovo doesn't have to deal with Mass inspections | |
| Subject: Re: FS: afterburner Headers NIB Thu Sep 09, 2010 8:45 am | |
| Actually, if you delete the air pump and all associated tubing and shit, most visual inspections will never notice they are missing. Even in MA. I've had cars registered and inspected with no air, no egr, and headers, with headers, without knowing a guy. | |
| Subject: Re: FS: afterburner Headers NIB Thu Sep 09, 2010 9:46 am | |
- Actually, if you delete the air pump and all associated tubing and shit, most visual inspections will never notice they are missing. Even in MA. I've had cars registered and inspected with no air, no egr, and headers, with headers, without knowing a guy.
Absolutely correct. You'd need to find an inspection Nazi to get bounced for any of those. Also ANY exhaust shop worth going to can hook reducers to cats, just take the flange (or flanges) off the cat & they'll weld it right up Bring it in loose so they can weld BEFORE the final install | |
| Subject: Re: FS: afterburner Headers NIB Thu Sep 09, 2010 10:10 am | |
| $150 PRICE REDUCED!!!!!! DONT NEED EM | |
| Subject: Re: FS: afterburner Headers NIB Thu Sep 09, 2010 10:55 am | |
| Non way to pre-fab those hook-ups Steve. Unless they copy what someone else has done. No way to use the stock cats either. If you want them, use the 60 dollar high-flow bullet ones from summit or the like.
| Subject: Re: FS: afterburner Headers NIB Thu Sep 09, 2010 1:24 pm | |
- Non way to pre-fab those hook-ups Steve. Unless they copy what someone else has done. No way to use the stock cats either. If you want them, use the 60 dollar high-flow bullet ones from summit or the like.
Ya, sorry for the bad advise. That would be shorties. Dont know afterburners. | |
| Subject: Re: FS: afterburner Headers NIB Tue Sep 14, 2010 11:15 pm | |
| $125 PRICED DROPPED AGAIN
125$ FOR HEADERS ARP BOLTS AND GASKETS | |
| Subject: Re: FS: afterburner Headers NIB Tue Sep 14, 2010 11:17 pm | |
| - BoSStonsSS wrote:
- $125 PRICED DROPPED AGAIN
125$ FOR HEADERS ARP BOLTS AND GASKETS very tempting | |
| Subject: Re: FS: afterburner Headers NIB Wed Sep 15, 2010 8:53 am | |
| Subject: Re: FS: afterburner Headers NIB | |
