 Did a smoke test today
PostSubject: Did a smoke test today   Tue Aug 17, 2010 10:06 pm
Found that on the intake side of the engine, the throttle shaft leaks from around the spring area...any ideas on what the best course of action is? Maybe a new TB, somehow. Not too too important, but I'd like to fix it.
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:28 pm
I've got a TB you can have if you want it...
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:29 pm
You talking cooling system or air system for the smoke? If it's cooling then it's probably the gasket on top. If it's air intake then I'd guess that there's just a little play where the throttle shaft passes through the housing. I don't know if there's an o-ring in there or not since most people aren't as concerned with that stuff as you and wouldn't ever notice Razz
Take one apart and see if it's an o-ring system and if so then you can fix it. If it's just a matter or being a "press fit" type setup then the housing is probably just wearing down a bit and would need to get swapped out. Either way it's going to be more trouble then it's worth since the throttle body isn't a dry system.
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:31 pm
I can grab it sunday...Thats still on correct???
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:32 pm
It's the intake side, I just like to know everything. thats all... geek
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:34 pm
Yup
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:35 pm
Best I can do without bothering to try Razz
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:43 pm
Yup
Would it be terrible if we got there around 9:00 am? My then wife, has to open her building at work a 6:30 am and we are getting married the day before. We are going to swing it...go big or go home I guess. We will try to get away early, maybe 6 and be there on time...we'll see.
PostSubject: Re: Did a smoke test today   Tue Aug 17, 2010 10:44 pm
I have that somewhere. Thanks. its from the spring side...so probably an o ring, we'll see what the new one does after sunday
» MGP filming today (update: new pics in thread)
» TTA Road test
» Stupidity test failed
» Threw in the PCM today!
