 Rolling an Odometer back
PostSubject: Rolling an Odometer back   Sun Aug 15, 2010 12:03 pm
No I'm not trying to make the wagon have less miles. I bought a 91-93 9C1 cluster but has higher miles than my car so I wanted to roll the cluster back to match. Anyone know how to do that?
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 1:31 pm
Put it in the car, jack it up and put it in reverse at WOT.
JRS9C1
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 1:48 pm
Bueller...
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 2:16 pm
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 2:20 pm
i hope your good at soldering.
ive had a 9c1 cluster sitting around for years because im not very good at soldering.
did you get the plugs that clip into the dash also?
they need to have about 6" of wire still attached to make re-wiring easy.
i have (somewhere) which wires go where when changing plugs.
if this is all new info to you sorry.
the reg. caprices 91-93 have a 1 plug dash cluster connector.
9c1 and occ clusters have 2 plug connectors.
i can take a pic of the back of both clusters if this makes no sense.
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 2:23 pm
Yeah, someone on longroof was giving me the rundown. I'm hoping the guy included some of the harness. And no, I suck at soldering. I may use those solderless connectors.
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 2:27 pm
if you need that info on the wires to switch ill take a look for it.
there use to be a thread about the swap on issf that had alot of good info.
but it might have gone away with the crash.
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 2:57 pm
On analog guages you can open it up and spin the number wheels gently. No Price is Righting the thing. On digidash units even the reverse trick don't work. It'll need to be reprogrammed by someone.
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 3:23 pm
Its an analog 9C1 cluster. Does the reverse thing actually work? I thought that was just an urban legand? Not that id actually do that lol.
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 4:10 pm
If it's an old car with a completely mechanical speedo then the reverse trick may just work Wink
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 4:19 pm
the old cable drive speedo use a drill in reverse Like a Star @ heaven
PostSubject: Re: Rolling an Odometer back   Sun Aug 15, 2010 7:43 pm
What size drill bit? Laughing I crack myself up jocolor
» Showmans / Road loco rolling chassis
» Tube Rolling with the ST120
» Crikey! Back issues
» Itachi is back!
» One Step Forward, Two Steps Back
