| | F/S 225/60/17 Dunlop SP4000T Run flat tires | |
| Author | Message |
 | Subject: F/S 225/60/17 Dunlop SP4000T Run flat tires Fri Jul 30, 2010 4:08 pm | |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Fri Jul 30, 2010 4:17 pm | |
| I'd grab those in a second if I had wheels to put them on. That's a great deal |
Posts: 674 Join date: 2009-02-02 Age: 24 Location: Easton MA
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Sat Jul 31, 2010 10:49 am | |
| GL with the sale, id try craigslist. That's a good price your askin. I've seen Sienna's chew those tires up in less than 30k, you should be able to sell quickly! |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Wed Aug 04, 2010 2:18 pm | |
Posts: 1297 Join date: 2009-03-24 Location: Walpole, NH
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Wed Aug 04, 2010 2:59 pm | |
| Billy, how are these as far as road noise? We have a noisy set on the Suby, if these would fit and are relatively quite, I would grab them.
Doug |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Wed Aug 04, 2010 3:11 pm | |
| | Pooge wrote: | Billy, how are these as far as road noise? We have a noisy set on the Suby, if these would fit and are relatively quite, I would grab them.
Doug |
I know they were just starting to chop on the outside edges due to a bad alignment. They were a little noisey. A simple rotation would have fixed it. |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Wed Aug 04, 2010 3:57 pm | |
| I'll check her tire size and get back to you. Her tires are louder than my chopped up BFG All Terrains... it's incredibly annoying Doug | IMPALADAKID wrote: | | Pooge wrote: | Billy, how are these as far as road noise? We have a noisy set on the Suby, if these would fit and are relatively quite, I would grab them.
Doug |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Mon Aug 09, 2010 2:24 pm | |
Doug |
Hows about $100? |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Mon Aug 09, 2010 2:28 pm | |
| Sorry Billy, no dice, they are too big
Doug |
Posts: 3009 Join date: 2010-03-14 Age: 24 Location: Chicopee, MA
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 10:07 am | |
| Billy, how big is the difference between 225/45/17 and 225/60? I have stock 45's on my VW... |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 12:24 pm | |
| Stock Tire - 225/45R17 ------------------------- 225/60R17 Rim Width Range: 7 - 8.5 in ----------------------- Rim Width Range: 6 - 8 in Overall Diameter: 24.97 in 634.23 mm ------------- Overall Diameter: 27.62 in 701.54 Sidewall Height: 3.98 in 101.09 mm ------------- Sidewall Height: 5.31 in 134.87 mm Circumference: 78.44 in 1992.3 mm ------------- Circumference: 86.77 in 2203.9 mm Speedometer Difference: - Speedometer Difference: 10.61% too slow Diameter Difference: - Diameter Difference: 9.6%
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 4:00 pm | |
| | sdstick wrote: | Stock Tire - 225/45R17 ------------------------- 225/60R17 Rim Width Range: 7 - 8.5 in ----------------------- Rim Width Range: 6 - 8 in Overall Diameter: 24.97 in 634.23 mm ------------- Overall Diameter: 27.62 in 701.54 Sidewall Height: 3.98 in 101.09 mm ------------- Sidewall Height: 5.31 in 134.87 mm Circumference: 78.44 in 1992.3 mm ------------- Circumference: 86.77 in 2203.9 mm Speedometer Difference: - Speedometer Difference: 10.61% too slow Diameter Difference: - Diameter Difference: 9.6%
But will they fit on my stock rim? I might snag them for a set of spares. |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 4:04 pm | |
| If you have a 17" rim then they should fit. No guarantee on the fender clearance though. Same width but a taller tire. |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 4:09 pm | |
| | Cadet57 wrote: | | sdstick wrote: | Stock Tire - 225/45R17 ------------------------- 225/60R17 Rim Width Range: 7 - 8.5 in ----------------------- Rim Width Range: 6 - 8 in Overall Diameter: 24.97 in 634.23 mm ------------- Overall Diameter: 27.62 in 701.54 Sidewall Height: 3.98 in 101.09 mm ------------- Sidewall Height: 5.31 in 134.87 mm Circumference: 78.44 in 1992.3 mm ------------- Circumference: 86.77 in 2203.9 mm Speedometer Difference: - Speedometer Difference: 10.61% too slow Diameter Difference: - Diameter Difference: 9.6%
Would raise the car about an 1 1/4", and tuck in the fenderwells at the top the same. Could fit, but would throw your speedo off as Steve mentioned. |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Tue Aug 10, 2010 11:11 pm | |
| | IMPALADAKID wrote: | | Cadet57 wrote: | | sdstick wrote: | Speedometer Difference: - Speedometer Difference: 10.61% too slow
....... but would throw your speedo off...... |
Do you drive the VW in the winter? I always liked a tall tire in the winter and the larger diameter wont hurt there either. As far as the speedo... its a built in excuse... Officer I just put on these new tires & I THINK they messed up my speedo....DUH!
For the $ you cant go wrong |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Wed Aug 11, 2010 9:34 am | |
| | sdstick wrote: | | IMPALADAKID wrote: | | Cadet57 wrote: | | sdstick wrote: | Speedometer Difference: - Speedometer Difference: 10.61% too slow
I do. My VW is my daily. I'm gonna give my buddy a call, he has thrown bigger tires on his. I'll see what he says. Like you said, its a good price. |
 | Subject: Re: F/S 225/60/17 Dunlop SP4000T Run flat tires Fri Aug 20, 2010 12:23 pm | |
| I can bring these sunday if anyone is interested. |
