| underdrive pulley? | |
| Subject: underdrive pulley? Sun Jul 18, 2010 12:42 pm | |
| i am in need of a new belt. does annyone know what size and if i can get t from advance or autozone? iknow i cant use a regular belt | |
| Subject: Re: underdrive pulley? Sun Jul 18, 2010 5:12 pm | |
| Just match it to the belt that's on there now. | |
| Subject: Re: underdrive pulley? Sun Jul 18, 2010 5:45 pm | |
| That belt is stretched out and split in half I think I found a dayco that fits but have to wait a day for it.. | |
| Subject: Re: underdrive pulley? Sun Jul 18, 2010 9:50 pm | |
| - BoSStonsSS wrote:
- That belt is stretched out and split in half I think I found a dayco that fits but have to wait a day for it..
Belts do not really stretch more than a half inch over the entire length. They do get worn and cracked. If your current belt feels a little loose, I bet the tensioner pully needs replacing as well. |
| Subject: Re: underdrive pulley? Sun Jul 18, 2010 10:11 pm | |
| Ill try again 2morrow the belt I have is 59.5 and it didn't fit but a guy on the issf has a gatorback and that is 59.25 inches and it fits | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 9:30 am | |
| Do I have to put it on that underdrive pulley..what's the pulley in front of it | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 10:38 am | |
| take it off and run a stock belt | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:14 am | |
| - mean ss wrote:
- take it off and run a stock belt
thats what i was thinking. dont i need a special too? | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:22 am | |
| I never had one but I think they just bolt on behind the stock balancer,it should be 3 bolts that hold it on and you might need 3 shorter bolts when you remove it | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:34 am | |
| i think im going to need the pulley removal tool | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:37 am | |
| no , I think you just leave the hub on and just remove the balancer | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:54 am | |
| the problem is the original belt snapped off so if i try to loosen the bolt it just moves freely | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 11:59 am | |
| if you had an air gun they would come right off, if you hit the ratchet fast with the palm of you're hand you can break the bolts free | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 12:50 pm | |
| Put a wrench on one bolt and angle it so that it's pressed against the hub or another bolt. Just something to keep the wrench from turning in relation to the bolt it's on. Then you can break free the bolt opposite that one since the wrench will let you hold the pulley in place. | |
| Subject: Re: underdrive pulley? Wed Jul 21, 2010 1:02 pm | |
| [b]FOUND A BELT!!!!!!!!!!!!!!
Q. What size belt will I need after I install my Underdrive pulley kit? (part numbers affected include: 1513, 1528, 1553, 1554, 1555, 15550, 1559, 1591, 1598, 1603, 1619, 1620)
A. Most all of our kits will be able to retain the stock belt size. The only kits that will need a new belt size will say so in the instructions, and have the part number for the new belt listed as well. Rule of thumb: If your instructions don't mention the need for a new belt, you should just re-use your factory-sized belt. However, if you still experience a condition which you feel a shorter or longer belt would alleviate, simply contact your local auto parts store and verify the factory-standard belt size. The belt size should be a part of the part number it self. For instance, if the part number ends with 88 or 885, it is more than likely an 88 or 88- ½ inch belt. So you can simply use the same style belt that is an inch-or-so shorter or longer in overall length. | |
| Subject: Re: underdrive pulley? | |
