| Stupid question? | |
+3bammax toomanytoyz onehunglo 7 posters |
onehunglo
| Subject: Stupid question? Wed Jun 30, 2010 4:49 pm | |
| Can you remove the oil filter on an LT1 without draining and not lose a lot of oil? | |
| Subject: Re: Stupid question? Wed Jun 30, 2010 6:27 pm | |
| Well most of the oil is in the pan, and there's no way for it to get to the filter without it running, so I think you'd maybe only lose what's in the filter and what may drip down out of the oil cooler lines... Why? | |
| Subject: Re: Stupid question? Wed Jun 30, 2010 8:19 pm | |
| The filter holds about a quart of oil so you'll be a quart low when you put the new filter on. | |
| Subject: Re: Stupid question? Wed Jun 30, 2010 8:40 pm | |
| can u change a flat tire without takin the wheel off?? | |
| Subject: Re: Stupid question? Wed Jun 30, 2010 8:48 pm | |
| - 96slowss wrote:
- can u change a flat tire without takin the wheel off??
Yes you can. i wouldn't recomend it though. The crowbars used to dismount the tire would damage the fender. | |
onehunglo
| Subject: Re: Stupid question? Wed Jun 30, 2010 9:12 pm | |
| Close enough If it went on without binding and isn't leaking then it probably fits. Many of the filter options are based on size/shape/capacity so they're somewhat interchangable. | |
| Subject: Re: Stupid question? Thu Jul 01, 2010 2:43 am | |
| How many licks does it take to get to the center of a tootsie roll pop? | |
| Subject: Re: Stupid question? Thu Jul 01, 2010 9:19 am | |
| Subject: Re: Stupid question? Thu Jul 01, 2010 11:52 am | |
| Remove the filter. Dump oil within it into the new filter. Start er up, shut er down. Check & add. This assumes that the above can be done without bringing dirt & grime into the picture.
onehunglo
| Subject: Re: Stupid question? Wed Jul 07, 2010 9:29 am | |
| I realized I never commented back... Filter swap was fine, albeit minnimal oil leaked on the converter. | |
Waldo617
Posts : 194 Join date : 2010-03-20 Age : 35 Location : Milton
| Subject: K&N Wrench off Oil Filter Wed Jul 07, 2010 5:52 pm | |
| you cant go wrong with the K&N Performance Wrench Off oil filters
they have a 1" nut welded to the bottom of the filter for easy removal | |
| Subject: Re: Stupid question? | |
