 Stupid question?
onehunglo
PostSubject: Stupid question?   Wed Jun 30, 2010 4:49 pm
Can you remove the oil filter on an LT1 without draining and not lose a lot of oil?
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 6:27 pm
Well most of the oil is in the pan, and there's no way for it to get to the filter without it running, so I think you'd maybe only lose what's in the filter and what may drip down out of the oil cooler lines...
Why? Question
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 8:19 pm
The filter holds about a quart of oil so you'll be a quart low when you put the new filter on.
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 8:40 pm
can u change a flat tire without takin the wheel off??
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 8:48 pm
Yes you can. i wouldn't recomend it though. The crowbars used to dismount the tire would damage the fender.
onehunglo
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 9:09 pm
Why? Question
Well, stupid me, long story short I have the Mobil M1-101 on there and I should have the 102. Embarassed
PostSubject: Re: Stupid question?   Wed Jun 30, 2010 9:12 pm
Close enough Laughing
If it went on without binding and isn't leaking then it probably fits. Many of the filter options are based on size/shape/capacity so they're somewhat interchangable.
PostSubject: Re: Stupid question?   Thu Jul 01, 2010 2:43 am
How many licks does it take to get to the center of a tootsie roll pop?
PostSubject: Re: Stupid question?   Thu Jul 01, 2010 9:19 am
3 (according to Mr. Owl)
PostSubject: Re: Stupid question?   Thu Jul 01, 2010 11:52 am
Remove the filter.
Dump oil within it into the new filter.
Start er up, shut er down.
Check & add.
This assumes that the above can be done without bringing dirt & grime into the picture.
onehunglo
PostSubject: Re: Stupid question?   Wed Jul 07, 2010 9:29 am
I realized I never commented back... Filter swap was fine, albeit minnimal oil leaked on the converter.
Waldo617
PostSubject: K&N Wrench off Oil Filter   Wed Jul 07, 2010 5:52 pm
you cant go wrong with the K&N Performance Wrench Off oil filters
they have a 1" nut welded to the bottom of the filter for easy removal
Stupid question?
