 chevy truck help??
PostSubject: chevy truck help??   Sat Jun 26, 2010 12:21 am
So since my wagon is waiting for a transmission ive been driving the Burb and I have a problem now. Its stuck in park!
Truck is a 1999 Chevy Suburban 2500, 4x4, Diesel. Its stuck in Park. I tried pushing it forward with my friend in the truck to put it in gear, that didnt work. Brake lights DO come on so I dont think its the brake switch.. whats the problem? Any ideas? Thanks guys.. -Paul
PostSubject: Re: chevy truck help??   Sat Jun 26, 2010 8:34 am
Is the truck on an incline? I would think it is the brake neutral safty switch.
PostSubject: Re: chevy truck help??   Sat Jun 26, 2010 8:37 am
Climb under and make sure the linkage isn't broken or binding. I know that's where I'd look before I start checking switches and sensors. Try manually putting it into gear at the trans and that'll tell you if there's something wrong internally or externally.
21/4tonsoffun
PostSubject: Re: chevy truck help??   Sat Jun 26, 2010 12:16 pm
With the key on and engine off step on the brake pedal and listen for the faint click of the shifter release solenoid.
The wagon did the same thing when i bought it and it was a bad connection at the brake switch.
chevy truck help??
» Big Blue Chevy Truck
» 4 15x8 Chevy/GMC truck/van rally wheels with new whitewall tires
» Chevy truck with sled deck and 1/24th scale diecast sled.
» I am getting the itch for a newer truck
» 1955 Chevy Cameo Pickup (Chopped + Jacked rear)
