Project T-56 EmptyWed Oct 19, 2022 1:27 pm by scot
Project T-56 EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Project T-56 EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Project T-56 EmptyFri Sep 24, 2021 9:53 am by ElKy
Project T-56 EmptySun Sep 19, 2021 6:22 pm by black blur 96
Project T-56 EmptySun Jun 20, 2021 11:37 am by scot
Project T-56 EmptyFri Jun 11, 2021 10:41 am by scot
Project T-56 EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Project T-56 EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Project T-56
5 posters
Project T-56 Empty
PostSubject: Project T-56   Project T-56 EmptyFri Dec 11, 2009 4:48 pm
OK guys it's official, 95 B4U is going to recieve a T56 transplant. I'm starting to search for a T-56 so I guess I need one out of 92-97 f body? Is this the only one that I should be searching? LMK guys cause I don't have a clue about how to install and really what to look for. I did learn on a standard when I was 14 ,so driving one is going to be a blast, I can't wait!
Thanks guys
Project T-56 Empty
PostSubject: project t-56   Project T-56 EmptyFri Dec 11, 2009 5:21 pm
i believe i had heard you were going to install a std. if only i had known. ive sent t56 parts all over. all i have left is a 95 camaro z28 used clutch and pressure plate. and a new inspection plate. thats it. sorry. you will have fun. i do.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptyFri Dec 11, 2009 5:23 pm
No T56 in '92s F-bodies. 93s had two with lower gear ratios (and torque ratings). You'll have to decide if they are acceptable.
I vote for one from a Firebird. We don't need people hacking up nice Camaros just to get the tranny.
Project T-56 Empty
PostSubject: project t-56   Project T-56 EmptyFri Dec 11, 2009 5:28 pm
you need a 94-97 camaro z28 or pontiac trans am tranny. mine came out of a 95 z28. i bought mine from e-bay. $2125.00 delivered. from ga. and its been excellent. no problems.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptyFri Dec 11, 2009 5:54 pm
Thanks guys
CPT broke again? scratch
Project T-56 Empty
PostSubject: project t-56   Project T-56 EmptyFri Dec 11, 2009 5:58 pm
nope. ill let tom explain what hes going to do.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptyFri Dec 11, 2009 7:18 pm
Like Jim said, 93-97 F body. 93 M29 has a lower torque rating, but the ratios are better suited to a higher gear like a 3.42 or 3.73 to try and keep the driveshaft revs down and maybe avoid having to buy an aluminum driveshaft.
If you're just gonna street drive it, a stock clutch will be fine. I use the Autozone clutch. And I think I am on my 7th warranty swap. Wink If you are going to race it, go with a stock LT4 setup. That's what I should have done both times. Right now I have a Zoom HP clutch. Sucks.
I get my tranny's from Robertson's in Wareham, Ma. http://robertsonautosalvage.net/ $1100 for EVERYTHING. <---TWICE! Very Happy Including the wiring harness, clutch, flywheel, shifter, crossmember, mount, tranny, hydraulics, pedals, switches, and all associated bolts and hardware. One stop shopping is hard to beat.
That, an F2B kit, and a weekend of thrashing, and you have a T56 Bee for 1500 bucks. Not bad. Wink
Plan on gears soon, though, if you don't have them already. Maybe adriveshaft, too, if you have vibes. These two items are another G easy, so keep that in mind.
Hope you'll be rowin' your boat soon! Ain't nuthin' better!
Project T-56 Empty
PostSubject: project t56   Project T-56 EmptyFri Dec 11, 2009 9:04 pm
thats about the going price. and when i bought mine on e-bay. it started at around $1400.00 for every thing. but in the last couple of mins. some one wanted it as bad as i did. well not as bad as me. i had my max bid quite high. i,ll admit i paid to much. Sad but it was worth it.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptyMon Dec 14, 2009 12:04 pm
So my orig drive shaft will work with the T56? I have vibration issues with my DS at high speeds, so I'm most likely going to get a Al DS.
Project T-56 Empty
PostSubject: project t-56   Project T-56 EmptyMon Dec 14, 2009 9:47 pm
yes it will tom. i installed a aluminum drive shaft in mine tho. and i still have my stock one. if you should need it.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptySat Jun 12, 2010 9:42 pm
Here we go! As soon as I get the 94 9C1 on the road and I'll be ordering soon.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptySun Jun 13, 2010 5:43 pm
Did a search for a 1994-97 T56 and didn't find anything. Going to call Robertson's auto salvage Monday and see what they have. They showed nothing online.
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptySun Jun 13, 2010 8:58 pm
I've had pretty good luck with them. Smile
Project T-56 Empty
PostSubject: Re: Project T-56   Project T-56 EmptySun Jun 13, 2010 9:07 pm
Tom, there are some decent deals on CL right now, a couple T56s in Mass for $1100. Use Searchtempest.com to check out pretty much every CL in NE.
Thanks,
Project T-56 Empty
Project T-56
» New Project.
» Project L99
» My son's first project......
» The L99 Project
» Post Pics of your B or D body(s)
