February 2018
 Window Motor
PostSubject: Window Motor   Tue Jun 01, 2010 1:41 pm
Anyone ever do one?
Window is stuck up. Worked randomly before (havent SLAMMED the door to get it to work once more)
12V+ & 12V- at the motor but no movement
I see the 4 rivets, but the regulator & motor are married.
Hints are appreciated.
druzdcm
PostSubject: Re: Window Motor   Tue Jun 01, 2010 2:13 pm
PostSubject: Add info   Tue Jun 01, 2010 4:16 pm
Thanks, I had searched & even asked the ? but that link didnt come up
Now I need to figure out if I want to R&R the whole assy or go after the brushes
Always seems easier with it out where you can work on it
I just fear not being able to get it out & screwing up the alignment or something stupid like ruining the tint
Realized I searched window motor
Should of also searched window regulator
PostSubject: Re: Window Motor   Wed Jun 02, 2010 9:38 am
Well, that was a piece of cake
Once I gave up on trying to get the motor ONLY the problem went away
8 rivets, pop it out of the track at the window, remove the lower track & it jumped out at me
Thanks for the link Drew
druzdcm
PostSubject: Re: Window Motor   Wed Jun 02, 2010 10:15 am
I hope to not being doing one of those! I hate removing the door panels. I have reinforced mine with basically hot glue with several sticks on each panel.
Window Motor
» Window motor replacement
» Need a driver's side window regulator
» GN rear window mod
» power antenna motor problem
