Stipped front shock upper stud EmptyWed Oct 19, 2022 1:27 pm by scot
Stipped front shock upper stud EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Stipped front shock upper stud EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Stipped front shock upper stud EmptyFri Sep 24, 2021 9:53 am by ElKy
Stipped front shock upper stud EmptySun Sep 19, 2021 6:22 pm by black blur 96
Stipped front shock upper stud EmptySun Jun 20, 2021 11:37 am by scot
Stipped front shock upper stud EmptyFri Jun 11, 2021 10:41 am by scot
Stipped front shock upper stud EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Stipped front shock upper stud EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
druzdcm
8 posters
druzdcm
druzdcm
PostSubject: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 9:17 pm
It's ok-laugh! I have the nut off but a few threads and the top is stripped. Anyone have this happen before?
I have taken a break from this since the top stripped, banged my hand, and I am somewhat frustrated...anyone have this before-advise?
Next time I am throwing some $ at someone to do this Very Happy
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 9:40 pm
I think what a lot of guys do is just put a deep socket on it and rock it till it snaps...
Have you tried vice grips on the shaft and an impact on the socket?
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 9:43 pm
I just grind the side of the nut a little with a hand grinder . it will split when you go to take it off
druzdcm
druzdcm
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 9:54 pm
Bill-I was thinking about that-I will grab my vise grips set from work 2morrow and clamp on the shaft and impact that bad boy off.
Bob-with the control arm on I don't know how to get a grinder in there.
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 10:00 pm
put a jack under the control arm and raise it as far as you can the see if you can get a cut off wheel in there
from under the control arm
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 10:58 pm
One of these micro grinders can get into tight places. Not a lot of power and it will take some time but mine has out lived two electric "dremels".
Stipped front shock upper stud Image_1381
Next time I'm gonna get me one with more power: big model.
Stipped front shock upper stud Image_1043
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyMon May 10, 2010 11:30 pm
I have a cordless dremel and some disc's specific for metal cutting and it works great. I've never tested it on something as large as a bolt though. It makes quick work of brackets I know. I'd imagine if you go all out and burn through a couple disc's it would cut through the nut eventually.
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyTue May 11, 2010 6:17 am
If you are replacing the shocks, take a deep 9/16 socket and place over nut, get a couple long extensions and start going back and fourth til the shock bolt fractures. This works every time. But you will need to tighten the nut back down for it to work.
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyTue May 11, 2010 7:15 am
What if you want to save the shocks? I have several cars that have good ones.
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyTue May 11, 2010 8:03 am
Very carefully grind off one side of the nut. Stop when the threads just start to show. Then you should be able to spin the nut off. It takes a long time to do with a dremel.
druzdcm
druzdcm
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyTue May 11, 2010 8:33 pm
Soooo I went with Billy's method-rock'r till she breaks!
I guess I will go over the pass side and not bother with the nut/stud method-what's the point if I got new shocks goinng on?
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyTue May 11, 2010 11:54 pm
Which Bill?
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyWed May 12, 2010 2:57 am
Which Bill?
All of them
druzdcm
druzdcm
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyWed May 12, 2010 5:49 am
Impalakid
PostSubject: stripped front shock upper stud.   Stipped front shock upper stud EmptyWed May 12, 2010 8:04 am
good for you. thats the best way to do them. now on to the next mod.
druzdcm
druzdcm
PostSubject: Re: Stipped front shock upper stud   Stipped front shock upper stud EmptyWed May 12, 2010 5:37 pm
mods...oh boy, I used to have UPS drop packages more than once a week and now the guy is sad he stops by less.
Smile
» How about an upper shock mount GP????
» Bill Harper's Rear Shock Upper Bolt Mod "Interest"
» Front Upper A-Arms
» Bilstein Shock #s
» Who is running Tubular upper/ lowers in the front?
