| Tru Trac Unit | |
| Subject: Tru Trac Unit Fri May 07, 2010 4:27 pm | |
| Ok, so before i F this thing up, how do i get this damn tru trac out? There is just a big round hole with a piece in it with 5 holes, the middle one is threaded. Do i need a special tool? | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 4:32 pm | |
| Don't you just push in on the axles and take the C clip out, slide the axle out of the way, and it comes out? (After taking off the carrier bolts/brace thing) | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 5:00 pm | |
| I can't see any c clips or even the ends of the axle, it's just a huge mass of metal!!! Lol | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 5:46 pm | |
| Not exactly apples to apples here but try reading through this and study the pics.
tru-track install | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 5:51 pm | |
| first picture , should be the same disassembly http://www.chevyhiperformance.com/techarticles/148_0207_10_bolt_rearend_gear_install/index.html
extract the cross-shaft bolt (A) and cross-shaft (B). Then, spin the rearend until the ends of the axles are visible inside the carrier. Locate the axle C-clips and remove them by pushing the axles in toward the center to free them. Once the axles have been removed, you can unbolt the main caps and remove the carrier. | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 5:58 pm | |
| It's the Detroit true trac, it's doesn't have the standard unit. This has a complete case, there is one hole in it, it's not open like the standard posi units where u can remove the bolt, pull the pin, push in the axles ans remove the c clips. It has one piece in one side that has a very large piece in the hole with a bolt hole in it. I tried to remove it but I don't want to screw it up. There website does not have a procedure to remove it. I can't post pics here, it's the worm gear posi. | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 6:02 pm | |
| take out the bolt holding the axle spacer and side gear spacer you have the internal c-clip type http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_128482.pdf | |
| Subject: Re: Tru Trac Unit Fri May 07, 2010 7:17 pm | |
| Got it out, thank u, I saw what I was missing! | |
| Subject: Re: Tru Trac Unit | |
| Tru Trac Unit | |
