When I first got my Roadie, I needed a new rad because of the previous owner tightened the top hose to the point of breaking the plastic tank. So I replaced the rad and put a new thermo for good measure (WP was new)
Now when I drive the car, it bearly gets warm (about one line above cold) . When sitting in traffic, it will go to alittle over the middle (common for LT1 ive read) then the fan kicks on and lowers it to alittle before halfway. A/C cranks ice cold and secondary fan works properly.
I also have no heat. Not even a little warm. No matter where the temp gauge is it blows cold, to the point that raising the temp on the climate control when the A/C is on does nothing. (90 degrees to 60 is is pretty much the same) Also, when I got the car, the black plug to the A/C canister was unplugged?
Where should I start? I beleve it could be a number of things, but would like to know what to start checking in order.
Thanx
