 doesnt want to accelerate??
PostSubject: doesnt want to accelerate??   Fri Feb 27, 2009 1:37 pm
I have brand new ac delco plugs wires and cap and rotor
But the problem is wen ever i try to accelerate it takes a long time, i looked under hood and saw i had a lil coolant leaking jus lil ... Should i just wait till it dries out?
PostSubject: Re: doesnt want to accelerate??   Fri Feb 27, 2009 1:51 pm
What do you mean takes a long time? RPM raises slowly?
PostSubject: Re: doesnt want to accelerate??   Fri Feb 27, 2009 2:44 pm
rpm raises but no acceleration and sometimes here a ticking noise
PostSubject: Re: doesnt want to accelerate??   Fri Feb 27, 2009 3:37 pm
Ticking or pinging?
PostSubject: Re: doesnt want to accelerate??   Fri Feb 27, 2009 4:46 pm
Ticking
PostSubject: Re: doesnt want to accelerate??   Fri Feb 27, 2009 5:01 pm
Have you checked your tranny fluid? Maybe it's slipping?
Ticking could be an exhaust leak, loose torque converter bolts, broken flexplate, loose rocker arms, etc. Most likely, it's an exhaust leak.
It's possible both symptoms are unrelated, too. Wink
