| Air Pump Delete?? | |
+4bammax toomanytoyz V8Killer 96Brougham 8 posters |
| Subject: Air Pump Delete?? Tue Apr 13, 2010 9:10 pm | |
| I believe my RMW is an early 95.. What do I need to delete the air pump? Would like to do this @mod day if possible.. Thanks, -Paul | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 5:32 pm | |
| I remember doing that while I was stil at GM. I'll see what I can dig up. I remember removing the pump, capping a couple of things off, and something with the ecm? | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 5:43 pm | |
| You don't need programming for the OBD1 cars. You need a couple oil plugs, but I forget the size... 21mm, maybe? Nope, 22mm. That should do it. I got mine at my local parts store. | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 5:50 pm | |
| Ok, found it. Gm Bulletin# 01-06-04-011. Remove air pump relay (in secondary fuse box), put a plug over air box, & reflash for 96 "P" engines, 95 & 96 "W" | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 6:29 pm | |
| No flash needed if you leave the relay in place. Just plug the manifolds and sell the rest to someone who's too scared to do an inspection without it. Also make sure to get the sticker for the radiator shroud | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 6:55 pm | |
| Stupid question, but what does air pump delete do? | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 6:59 pm | |
| - Cadet57 wrote:
- Stupid question, but what does air pump delete do?
Pumps air. |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 7:30 pm | |
Pumps air. Wrong The air pump delete deletes the pumping of air. It makes the air pump not pump air and thereby and henceforth cancels all pumping of air through the air pump Plus it gives you something to put down as a mod, for those who care about such stuff | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 9:17 pm | |
| It cleans up the engine bay by A LOT. Just looks a lot cleaner. | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 9:18 pm | |
- It cleans up the engine bay by A LOT. Just looks a lot cleaner.
Hummm..... 1993 which means I dont need to pass emissions.... Does pulling the air pump kill mpg's? | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 9:20 pm | |
| Subject: Re: Air Pump Delete?? Thu Apr 15, 2010 10:01 pm | |
- air pump do?
Yes....I think dew in the air pump was what caused this TSB which cancels the aforementioned "all pumping of air through the air pump" Dew...moisture...OK Brad, mr. wizard, back me up on this | |
JRS9C1
| Subject: Re: Air Pump Delete?? Fri Apr 16, 2010 9:14 am | |
| I just ripped a bunch of junk outta the engine bay that looked useless.. | |
| Subject: Re: Air Pump Delete?? Fri Apr 16, 2010 11:04 am | |
| For the NH folk it's ok to remove the air pump:
http://www.inegma.net/mb/index.php?showtopic=4242 | |
| Subject: Re: Air Pump Delete?? | |
