possible 4l60e problem? EmptyWed Oct 19, 2022 1:27 pm by scot
possible 4l60e problem? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
possible 4l60e problem? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
possible 4l60e problem? EmptyFri Sep 24, 2021 9:53 am by ElKy
possible 4l60e problem? EmptySun Sep 19, 2021 6:22 pm by black blur 96
possible 4l60e problem? EmptySun Jun 20, 2021 11:37 am by scot
possible 4l60e problem? EmptyFri Jun 11, 2021 10:41 am by scot
possible 4l60e problem? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
possible 4l60e problem? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
tylerwerrin
6 posters
tylerwerrin
PostSubject: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 5:10 pm
hey guys,
got a 1996 impala lt1 with a 4l60e mated.
so the engine/tranny is successfully installed in a 1984 jaguar xj6. reverse seems to work just fine (feels powerful, like it should) but when i put it into a forward gear, i go nowhere. If i mash on the gas, i can get up to 10mph or so.
My friend says that if the connector plug (the large green one) is put on wrong, it will cause the tranny to do this, but the plug is on correctly. Is there anything that can be done with the tranny on?
There's a new filter installed, fresh fluid, etc. Tranny's condition was unknown when i put it on, but i was told it only had 60k miles on it. Are the forward gears smoked? input sprag?
any help would be most illuminating.
thanks,
tyler w.
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 8:42 pm
Damn, that's gotta be frustrating! I wish I knew more to help you... But there are a few guys on here that have been pretty deep into those tranny's that may be able to offer you some advice.
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 8:50 pm
Yah, lets get those jokers posting on here already!
tylerwerrin
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 8:53 pm
haha, any help would be great! really don't want to have to R&R...
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 8:56 pm
Sounds like the T/C may be toast. scratch Does it do it in all gears?
tylerwerrin
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 9:04 pm
maybe it went a little faster when i had it in 2nd -- but it might just be my imagination. i could go in reverse fine -- had proper acceleration -- felt really good.
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 9:06 pm
That means it must be deeper.
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 9:10 pm
http://www.impalassforum.com/vBulletin/showthread.php?t=227226
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 9:21 pm
Two possible answers based on your description of symptoms.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
tylerwerrin
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptyFri Apr 09, 2010 9:31 pm
hmm, well that explains what my friend said about the plug being put on incorrectly -- the pink wire is hot for the transmission -- i'll have to fiddle with it, do some probing. hope its not the input sprag -- is there a way to test for power to the trans another way? i know the fuses are fine -- checked em last night.
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptySat Apr 10, 2010 5:34 pm
Shocked
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptySat Apr 10, 2010 6:05 pm
Shocked
Maybe i'll just sit the mod day out...
tylerwerrin
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptySat Apr 10, 2010 6:13 pm
haha. well, i guess scanning the pcm to figure out what the error codes could be would be a good first step -- too bad the car's injectors are currently being replaced, and waiting for new ones to come in the mail.... anyone know what kind of codes i should look out for?
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptySat Apr 10, 2010 6:29 pm
Shocked
Sounds like if you are not a tranny, you have nothing to worry about. Razz
tylerwerrin
PostSubject: Re: possible 4l60e problem?   possible 4l60e problem? EmptySat Apr 10, 2010 10:35 pm
hmm doing a little research seems to show that the PCM could go into limp home mode if the ignition switch isn't getiting enough voltage to the trans -- how does this make sense? the ignition switch is used to just engage the starter relay/starter, right? i wonder if the codes have been thrown in the PCM from before and are still there...
» Different day SAME problem
» Problem with ?
» My car just started fing up REAL bad.
» an odd ABS problem
» Air Dam Problem
