 code reader
PostSubject: code reader   Sat Mar 27, 2010 4:16 pm
Ok, i can't find the post with the Laptop info for code reader, i Downloaded Freescan. Need the cable. Anyone got the part #?
PostSubject: Re: code reader   Sat Mar 27, 2010 4:23 pm
datamaster is better and free for the first 20 logs and I got a cable from AKM
http://www.akmcables.com/ic.htm
http://www.ttspowersystems.com/DataMaster_downloads2.html
PostSubject: Re: code reader   Sat Mar 27, 2010 4:27 pm
Thank you, i was hoping to find a cheaper cable, but i'll have to bite the bullet, to bad i paid $200 for that stupid INNOVA
PostSubject: Re: code reader   Sat Mar 27, 2010 4:30 pm
there is a cheap cable I think it was from aknovaman? something like that from the forum
found it http://www.pcmperformance.com/cables.html
PostSubject: Re: code reader   Sat Mar 27, 2010 4:42 pm
That must plug into the PCM? Never seen that before.
PostSubject: Re: code reader   Sat Mar 27, 2010 4:45 pm
no it plugs into the pins in the connector under the dash Shocked "cheap"
PostSubject: Re: code reader   Sat Mar 27, 2010 5:33 pm
ya, for $50 i can make one that i can screw up, I'll go with the more expensive one from AKM
PostSubject: Re: code reader   Sat Apr 03, 2010 8:45 am
Will this work with the freescan and other Laptop scanners? I downloaded Datamaster, need to find out what the hell is going on with my Impala.
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
PostSubject: Re: code reader   Sat Apr 03, 2010 10:17 am
Yes. You just need to be able to have your pc or lap top be able to communicate with your pcm in the car. That will work.
code reader
