February 2018
 Look what I picked up today!
PostSubject: Look what I picked up today!   Mon Mar 22, 2010 8:53 pm
And I wasn't even looking for one!
(there was also about an inch and a half IN THE TIRE!)
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 8:56 pm
If your not using it, can I have it? Any pics from inside the tire. Razz
Seriously, that sucks dude.
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 9:19 pm
It's not so bad. Sure did make a lot of noise hitting the inner fenderwell though!!! Wink
I plugged the tire when I got home. Hopefully it'll seal up over night, it was still leaking a little when I put it back on. The hole the bolt left was effin HUGE! If it's still leaking in the morning, I'll see if I can have the mechanic at work patch it from the inside.
Not really a big deal, as it's a snow tire and it's the end of the season. Not even sure if they'd make it another winter as they are pretty close to the wear bars now. Only thing that does suck a bit is that the rims and tires I was gonna put on it won't fit until the impala disc rear is in there and I get the fender lips and trim rolled... So I'm left with having to put the SS's wheels on it, seeing as it's not using them anyways. Wink Only thing is, that I couldn't find the lock socket for the wheels or I woulda changed them over tonight. Dammit. cherry
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 9:42 pm
I hope it did not damage the car.
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 9:47 pm
DANG! That is huge, pointed or a regular bolt?
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 9:50 pm
It didn't damage it.
And it is a pointed, course thread bolt. Like 8-10 INCHES long!
WOW Shocked . Where did you pick that up? Might have been one of those phone company/power crews dropping bolts in the road Razz Ahh, just throw those on the back when we head up to the airport.
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 9:54 pm
That's the first thing I thought! I bet it's a power attachment of sorts. We don't use any that long. Damn those utility companies! Very Happy
I found it in Windham on 111 right near exit 3 where all those poles have recently been replaced.
Hey, uh... Know how to roll a fender without hurting the body lines?
PostSubject: Re: Look what I picked up today!   Mon Mar 22, 2010 10:01 pm
I did it on the T if you want to take a look. Slow, pain in the a** process. You can certainly do it without hurting the body, but it WILL crack the paint all off in the area you do it. You might be able to slightly tweak it with the "wooden bat" trick, but I don't think that will give you enough of what your looking for.
PostSubject: Re: Look what I picked up today!   Tue Mar 23, 2010 12:11 am
When I first saw the pic my reaction was "you should return it since it's bent and all". Looks a bit rusty too. I'd bring it back where you found it and exchange it for a straight one. Damn factory defects. That's what you get with imported chinese bolts Rolling Eyes
» A little treasure picked up today D834 Photo Frame
» Threw in the PCM today!
» new oven today help
» I'm giving a paper on POTO today!
» Lost a good friend today
