 1993 Caprice Wagon LT1 Swap?
PostSubject: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 3:11 pm
Hey guys,
I *should* be bringing home a pretty decent '93 Caprice Wagon this week. has a 5.7L TBI. My boss is looking at getting a new hearse (yes, I work at a funeral home Twisted Evil ) If he does. I want to see if he will sell it to me as the LT1 in it only has 55k and it runs and drives perfectly. How hard is it to swap this out? Another forum mentioned i'd need the ecu and trans (no surprise) and that id have to dent the frame to make room for the a/c compressor. Otherwise, anything crazy hard id need to do?
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 3:35 pm
The gen 1 and gen 2's are pretty much the same externally. You'd be able to use the same mounts, the same exhaust, some of the same accesories.
I don't see why you'd need to clearance the frame for a/c since the b-body frames are pretty much the same between those years anyway. The a/c sits close to the frame on a gen2 but not close enough to need to worry about clearancing things.
If you wanted to keep costs down you could keep running a 700r4 or 4l60 trans as long as there's a way to lock up the torque converter. Then you would only need the pcm to control the engine which makes things a bit easier.
Being tbi means your fuel system is already configured for fuel injection so other than a new pressure regulator, which usually comes with the motor anyway, you should be good to go. You may need a stronger fuel pump later though.
It's not as difficult a swap as say a gen3 would be, but not quite as easy as a 350 into a 305 car. Overall I'd expect it to take a week to get it all done and then get all the wiring straight. These engines have alot of complicated wiring Crying or Very sad
Might be worth while to get an engine wiring harness and remove the unused bits and label the rest to make things easier later.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 4:09 pm
Well its a "stock" LT1, 4L60E just on a stretched Fleetwood body. Will the driveshaft off my 93 work with the 4L60E? As the driveshaft is longer than stock on the donor car.
What kind of wiring am I looking at? I've never swapped an engine before. PCM and?
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 4:30 pm
Your car already has a 4l60 in it. The "e" version in the fleetwood is computor controlled by the same pcm as the engine. It'll be located under the air cleaner assembly in the front corner of the engine compartment. The driveshaft, crossmember, linkages, and everything else hardware wise will be the same between trans. You just need to run the wiring when you drop the new trans into the wagon.
The drivetrain swap would be easiest if you leave the wiring attatched to the engine/trans and just set the pcm on top of the intake during the removal procedure. Then once everything is out of the fleetwood you can see where everything goes and can do a proper install. You will have to remove some wiring to remove the drivetrain, such as fuel pump wiring, o2 sensors, and others. I just wouldn't remove any more than necesary.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 4:31 pm
By the way, you could always save yourself alot of wiring and just run a carb setup on the lt1 Wink
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 4:37 pm
I'd drive the hearse! Laughing
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 14, 2010 5:01 pm
LOL. I spend enough time in it. Plus it has a lot of electrical gremlins, PRNDL display is broken, radio doesn't work, stupid stuff like that.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Mon Mar 15, 2010 10:15 am
One more thing I just thought of. the '93 is OBD 1 right? The '96 is OBD 2 iirc. Will that make a difference?
LandMaster
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Mon Mar 15, 2010 3:10 pm
I'm not absolutely certain but supposedly in some states switching OBD-I to OBD-II will fail you for inspection. I know it is possible to wire up the LT1 as OBD-I, but I'm not sure what the difference is as far as electronics go for the 96s
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Mon Mar 15, 2010 3:49 pm
Well, here in MA. cars 95 and older don't get an emissions inspection as there is no OBD II, just a safety one so lights, horn, etc that kinda stuff. But will there be any issues with CEL's or stuff like that if I put the LT1 in an OBD I car?
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 1:21 am
Just use an obd-1 ecm and there are some changes to the transmission wiring and don't use the crank sensor in the timing housing.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 2:24 am
Dont mind me. I forgot the details.
If you use the engine and trans from the fleetwood then the pcm and wiring carry over with it. The drivetrain is obd-2 not the actual car. So just swap everything over, then wire the dash port for obd-2 so that you can still use a plug-in tool on it.
The only issue from there will be the abs which is completely different between the years your working with. Someone else just went through the issue of mixing abs parts and found the issues.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 11:26 am
So how should I tackle the abs? leave all the caprice parts or use the fleetwood parts?
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 1:14 pm
The fleetwood pcm will be looking to control the abs. I'd swap the abs box over to the wagon and then just replumb the lines to work with the fleetwood box. There may be an easier way but I wouldn't know of any off the top of my head. Seems like the easiest path is to take anything that the fleetwood pcm controls and swap it into the wagon to make the electrical part of the swap as easy as possible. No need trying to track down an electrical gremlin after all the hard work of swapping everything.
I think it was nomoa that was playing with the different year abs boxes. He could probably give you a better heads up on the issue.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 1:36 pm
hmm this is starting to get out of my league. I may just stick with the TBI and be happy with what I got Laughing
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 1:48 pm
I'd recomend you host a mod day. Find a suitable place, put the cars side by side, then see how many people are willing to come by and get dirty. If you find the right place, provide the right food, and pick the right day, you'll get enough people to show up and make a huge mess of your driveway Laughing
Course it probably wont all get done in one day, but it'll get you far enough along to where you can finish it yourself in your spare time without being overwhelmed.
Some people may only show up if you provide spare parts or gas money so be carefull Wink
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 1:57 pm
Well, if someone brings a big enough trailer. They can have the skeleton of a 96 Fleetwood hearse Laughing
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 5:34 pm
Dibs on skeleton. What a Face
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 6:11 pm
So SS parts into hearse Suspect
I'm hoping you say yes Twisted Evil
I'd love to see Billy in a Hearse SS Wink
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 6:30 pm
Well, if my boss is feeling generous when we finally get a new hearse....
@ bammax. An SS hearse would be INSANE Twisted Evil
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Tue Mar 16, 2010 7:13 pm
This is as close as I have ever come. cheers
Me getting spanked by a furd diesel truck.
PostSubject: Re: 1993 Caprice Wagon LT1 Swap?   Sun Mar 21, 2010 10:26 am
So i've been thinking more about this. I'd love to do it. I'm still just leery on the ABS thing. Everything else seems pretty straightforward, albeit time consuming.
» 1993 Caprice Wagon LT1 Swap?
» Morticia is FOR SALE! 95 Caprice Wagon...
» F/S 1993 Caprice LS Sedan
