 1995 GMC YUKON
nvss
PostSubject: 1995 GMC YUKON   Fri Feb 26, 2010 6:38 am
Hey boys, I know this isn't about a b-body, but it does have a 350. I went out this morning and started it, as I walked away it stalled out. Now it will not turn over!! I do know that it is fuel injected and to keep trying to turn it over it will flood. So my question is what can it be??
http://larcote@yahoo.com
PostSubject: Re: 1995 GMC YUKON   Fri Feb 26, 2010 8:50 am
Is it not doing anything at all when you turn the key, or is it cranking and not firing up? This truck should be a TBI- is it getting spark? Fuel? Shoot some starting fluid in the TBI while someone turns the key, if it fires up then (poorly but running), it's probably the fuel pump.
On my 93 I had the ignition module go, I was driving along, everything was fine, then the truck just stalled and rolled to a stop. Would crank but didn't start up. On a hunch I replaced the module while the truck was still on the side of the road, and that fixed it.
1995 GMC YUKON
» 1995 GMC YUKON
» FOR SALE LDM 1995 Caprice
» Beautiful 1995 Impala SS in the best color they made it in!!!
» 1995 9C1
» Vermont My 1995 Caprice for sale cheep! Look inside!
