Air Pump Delete?? EmptyWed Oct 19, 2022 1:27 pm by scot
Air Pump Delete?? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Air Pump Delete?? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Air Pump Delete?? EmptyFri Sep 24, 2021 9:53 am by ElKy
Air Pump Delete?? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Air Pump Delete?? EmptySun Jun 20, 2021 11:37 am by scot
Air Pump Delete?? EmptyFri Jun 11, 2021 10:41 am by scot
Air Pump Delete?? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Air Pump Delete?? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Air Pump Delete??
8 posters
PostSubject: Air Pump Delete??   Air Pump Delete?? EmptyTue Apr 13, 2010 9:10 pm
I believe my RMW is an early 95.. What do I need to delete the air pump? Would like to do this @mod day if possible.. Thanks, -Paul
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 5:32 pm
I remember doing that while I was stil at GM. I'll see what I can dig up. I remember removing the pump, capping a couple of things off, and something with the ecm?
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 5:43 pm
You don't need programming for the OBD1 cars. You need a couple oil plugs, but I forget the size... 21mm, maybe?
Nope, 22mm.
Air Pump Delete?? Manifoldplug
That should do it. I got mine at my local parts store.
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 5:50 pm
Ok, found it. Gm Bulletin# 01-06-04-011. Remove air pump relay (in secondary fuse box), put a plug over air box, & reflash for 96 "P" engines, 95 & 96 "W"
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 6:29 pm
No flash needed if you leave the relay in place. Just plug the manifolds and sell the rest to someone who's too scared to do an inspection without it. Also make sure to get the sticker for the radiator shroud
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 6:55 pm
Stupid question, but what does air pump delete do?
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 6:59 pm
Pumps air.
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 7:30 pm
Pumps air.
Wrong Razz
The air pump delete deletes the pumping of air. It makes the air pump not pump air and thereby and henceforth cancels all pumping of air through the air pump
lol!
Plus it gives you something to put down as a mod, for those who care about such stuff Laughing
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 9:17 pm
It cleans up the engine bay by A LOT. Just looks a lot cleaner.
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 9:18 pm
Hummm..... 1993 which means I dont need to pass emissions.... Does pulling the air pump kill mpg's?
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 9:20 pm
Pumps air.
Wrong Razz
lol!
Screw you know it all. geek
I missed the part about delete. I just read what does an air pump do?
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyThu Apr 15, 2010 10:01 pm
air pump do?
Yes....I think dew in the air pump was what caused this TSB which cancels the aforementioned "all pumping of air through the air pump"
Dew...moisture...OK Brad, mr. wizard, back me up on this
JRS9C1
JRS9C1
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyFri Apr 16, 2010 9:14 am
I just ripped a bunch of junk outta the engine bay that looked useless.. Laughing
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyFri Apr 16, 2010 10:22 am
Do they even have emissions in maine? Rolling Eyes
PostSubject: Re: Air Pump Delete??   Air Pump Delete?? EmptyFri Apr 16, 2010 11:04 am
For the NH folk it's ok to remove the air pump:
http://www.inegma.net/mb/index.php?showtopic=4242
Air Pump Delete??
» Air pump delete
» EGR tube delete
» A/C Delete tips and tricks
» A/C delete pully
» Mechanical Fan Delete
