» 2019 Twelfth Annual B & D Roundup!! Mark your calendar! Saturday October 19th
QUick Help  PLEASE EmptySat Sep 07, 2019 7:36 pm by bigbluey88
QUick Help  PLEASE EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
QUick Help  PLEASE EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
QUick Help  PLEASE EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
QUick Help  PLEASE EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
QUick Help  PLEASE EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
QUick Help  PLEASE EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
QUick Help  PLEASE EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
September 2019
Share
 QUick Help PLEASE
twotonsofsteel
PostSubject: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 4:22 pm
I tried the Primary fan fix as outlined but I couldn't get any spade connectors big enough, (I looked in 3 different places). SO I thought I would find switched power under the hood and just have it run when the car is on. Since the wiper motor is big amp I pulled the 6 wire connector off and found 12 volts on #1 & 4 (counting top down). So I tied in, wired it all up, and when everything was buttoned up and the key turned..no fan. I pulled the connector again got 12, checked fuse I installed inline and got 12, but when i plug the connector back in to the wiper I get 1.4?????
I need this car for work on Monday, can anyone tell me where I can find switched power under the hood? Please
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 4:45 pm
try the air pump or the air pump fuse in the fuse box
http://www.goldsswagon.com/diagrams/wiringindex.htm
did you fry the wires? might need a new fan motor, you should convert it to the stock twin fan
http://www.innovativewiring.com/ChevyProductPage2/ChevyCarsPage2/ChevyImpalaPage.htm
twotonsofsteel
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:02 pm
Since I removed the air pump, and have no need for the wires that once went to it, I will check that out. I doubt the pump was meant to run with the car off so that should be switched.....HHMM I will check it out after I eat
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:12 pm
You can get those spade terminals at a GM garage, I did when when I converted to the 2 fan system.
Tom C.
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:13 pm
The air pump connector itself won't provide you with the power your looking for. You need the hot wire at the air pump fuse which should be a switched hot if I'm not mistaken. Otherwise your fan will only power on when the ecm says to turn on the air pump and that wouldn't be much help to you.
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:23 pm
pull the air pump relay and jump the terminals
twotonsofsteel
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:31 pm
thank you all for the help...is the air pump relay in the 'box" where the Fan ones are? I need to do whatever I need to, to get it running but I think I am going to order the harness from the website you gave me
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:34 pm
Why cant you use the factory fans, or wiring? Just do what Bobby said. But find the primary fan relay, pull the relay, run a blade terminal to one side, and send the wire to a switch, and just return to the otherside. You will have direct power, switched that you can control and not have to run a lot of wires.
PostSubject: Re: QUick Help PLEASE   QUick Help  PLEASE EmptySun Feb 21, 2010 6:38 pm
QUick Help PLEASE
» QUick Help PLEASE
» Quick air layer
» Quick Shot and Fire Twice
