 Heater core clogged?
PostSubject: Heater core clogged?   Thu Feb 18, 2010 6:51 pm
Is it my heater core clogged? Add coolant light keeps coming on sk I add. Then it comes on again. There are no leaks outside so I felt the passenger side carpet and it is WET!!!!
PostSubject: Re: Heater core clogged?   Thu Feb 18, 2010 7:28 pm
Do you have an anti-freeze sweet smell inside the car? When you turn on your defrost, do your windows steam up? Are you loosing fluid?
Tom C.
PostSubject: Re: Heater core clogged?   Thu Feb 18, 2010 7:58 pm
I'm loosing fluid. No smell no steam
PostSubject: Re: Heater core clogged?   Thu Feb 18, 2010 8:13 pm
If your loosing fluid + your floor is wet = heater core probably needs replacing.
» heater core flow restrictor alternative?
» Heater Core Flush (Cold Air Fix!)
» WTB: '92-'93 HEATER HOSES (Quick-Connect type)
» [080726] Hyori - U Go Girl MBC Music Core [410M/tp]
» plastic heater hose tee
