» Looking for SEO 6J6 wiring [FOUND]
OBD 1 motor is a 96??? EmptyWed Aug 21, 2019 4:28 pm by MASShole9C1
OBD 1 motor is a 96??? EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
OBD 1 motor is a 96??? EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
OBD 1 motor is a 96??? EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
OBD 1 motor is a 96??? EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
OBD 1 motor is a 96??? EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
OBD 1 motor is a 96??? EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
OBD 1 motor is a 96??? EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
August 2019
Share
PostSubject: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 11:05 am
I know people do the conversions to OBD1...is this something I can do and pass NH state plug-in during inspection?
I have a line on a very clean 96 SS without motor/trans and I have a 95 motor/trans...If I can't do it I can wait till I get a 96 Parts car and throw that motor/trans in, but I want instant gratification...LOL
Anyone?
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 11:08 am
use the 95 computer, but you will loose the tach
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 11:31 am
Any problems come inspection time?
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 11:35 am
nope the 95 puter wont be looking for a crank sensor so no CEL
PS use the 96 coil and ICM
JaySS
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 12:11 pm
Use the '95 engine & trans and keep the OBDII PCM.
Otherwise you will very likely have problems during inspection, as the plug-in won't be able to communicate with the PCM.
You will not LOSE the tach, but it would read 2X with the '95 PCM as the '96 PCM is programmed for a 4 cylinder output.
Also expect the buyer to have issues when you go to sell it.
You'll need to change the timing cover, dampener hub and use the 4 tooth reluctor off of a '96 L99 or LT1.
The knock sensors will have to be swapped out also.
Be careful when breaking them LOOSE from the block as they are fragile Smile
If you still have the gold '96 engine, just swap those parts over and transfer the old stuff back to that one so you can still sell it for a '94 or '95 application.
- J
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 12:30 pm
Jay how is the f-bodys with OBD1 with the OBD2 data port wired
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 12:32 pm
I
For the love of god, where do you find stuff like that???????????
And for that matter, who in their right mind rips the motor and tranny out of a good 96
SWT SS
SWT SS
PostSubject: I think   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 2:48 pm
I think I'm going to LOSE my mind because I'm LOOSE in the pants!!! Razz
J you slay me!!!
CP
PostSubject: Re: OBD 1 motor is a 96???   OBD 1 motor is a 96??? EmptyWed Feb 17, 2010 3:15 pm
If
- J
OK, so basically I should just waite till I get a 96 parts car and swap the motor/tranny over (the Gold Caprice has REALLY high mileage and I have been slowly parting the motor, so that is a no go)...That will be a hell of a lot easier and won't be a mess if I go to sell it down the road...this will likely become a personal rig should it go down.
I have my ways... The guy claims it is a 45,000 mile car...I have pics and it is CLEAN, so he might be right, still seems crazy that the previous owner yanked the drive train from it...
Doug might have himself a new Impala! Now just to find me a 96 parts car now....this one is missing the floor shift and console as well as tail lights and other little ish that I have in the shop.
» Motorcraft 200k at Texas Motor Speedway
» Wanted: .10 Size Glow Motor
» Motors and Gearboxes from MFA Como
» cox space hopper .049
» Cox Conquest
