| Who is online? | In total there are 3 users online :: 1 Registered, 1 Hidden and 1 Guest :: 1 Bot sdstickMost users ever online was 29 on Tue Nov 29, 2011 7:36 pm |
| May 2013 | | Mon | Tue | Wed | Thu | Fri | Sat | Sun |
| | | 1 | 2 | 3 | 4 | 5 | | 6 | 7 | 8 | 9 | 10 | 11 | 12 | | 13 | 14 | 15 | 16 | 17 | 18 | 19 | | 20 | 21 | 22 | 23 | 24 | 25 | 26 | | 27 | 28 | 29 | 30 | 31 | | | Calendar |
| | | Bad radio signal/reception | |
Posts: 3939 Join date: 2009-07-30 Age: 31 Location: Reading, MA
 | Subject: Bad radio signal/reception Tue Jan 05, 2010 3:54 pm | |
| Any common problem with these cars to cause this?
My car has almost no AM reception in most areas, and all the FM ones suck. Sometimes I can hit seek, and it will only pick up 93.7 after cycling through the whole dial.
I figure this must be something to do with the antenna circuit. Does anyone know where the antenna's grounded (if so) and such? My car has one of the fixed mast antennas, not a power one.
I might try to toss another radio in there to see what happens. Have the factory CD player someplace from my brother's 94 RMS. |
|  | | toomanytoyz Club President
Posts: 5926 Join date: 2009-01-20 Age: 36 Location: Sandown, NH USA
 | Subject: Re: Bad radio signal/reception Wed Jan 06, 2010 3:46 am | |
| Did you make sure the antenna is plugged into the radio?
That said, I have always had poor reception in my cars, moreso the sedans than the wagons. Not near as bad as what you are experiencing though. _________________ Bill "The Verb" Crovo - Resident Car Slut 95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 95 9C1 -Project AutoX Slut- MAB!!<--Finally!! West coast car, rust free! T56 and suspension mods to come! 94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said. American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!"LOWER IT!!!  |
|  | | silverfox103
Posts: 1026 Join date: 2009-01-25 Age: 18 Location: Littleton, New Hampshire
 | Subject: Re: Bad radio signal/reception Wed Jan 06, 2010 4:31 am | |
| XM radio fixed my reception problems.
Tom C. |
|  | | Matt Trakker
 | Subject: Re: Bad radio signal/reception Sat Jan 09, 2010 9:23 pm | |
| ^haha
Bill I've yet to pull the radio out, I keep getting sidetracked. It's strange how in one spot the signal will be strong, then I drive a mile or two down the road and all of the stations except for two barely come in. I've had a radio work very poorly before with an antenna disconnected/hooked up poorly, so maybe it fell off up in the dash or something... |
|  | | Matt Trakker
 | Subject: Re: Bad radio signal/reception Sat Jan 16, 2010 11:39 am | |
| I pulled the dash apart yesteday, the radio antenna was plugged in, but may have been loose since I jiggled/pushed it in then turned it on, it stopped at all the stations when I hit seek.
Nevertheless, since I had everything apart I decided to toss the factory CD player from my brother's 94 Roadmaster in there...the bracket from my radio fit a little tight on the back of the CD radio (by like 1/16" too much) but it fit!
Haven't had a problem, works great now. |
|  | | Matt Trakker
 | Subject: Re: Bad radio signal/reception Thu Feb 04, 2010 5:44 pm | |
| Well, that didn't last long...within a day or so it was back to it's old BS. Plays CDs nice, it's definitely the antenna. Looks like I'll have to pull the inner fender well a little to see if I can get in the antenna in there...  |
|  | | Matt Trakker
 | Subject: Re: Bad radio signal/reception Fri Feb 05, 2010 10:39 am | |
| I forgot to mention this-
Whenever I get in or out of this car, and mostly over the past month or so, I get a WICKED shock from it, either from touching the top of the door skin, hitting the lock/unlock button with my finger, etc. It's pretty bad, enough so you can hear a zap and if it's dark you can probably see the blue flash too. Maybe I have a ground problem? I mean I get shocks all the time from stuff especially in the winter but none of my other cars were like this... |
|  | | Guest Guest
 | Subject: Re: Bad radio signal/reception Fri Feb 05, 2010 1:38 pm | |
| No Matt, that's just the dry winter air. Happens every winter. In most any car.  _________________ Bill "The Verb" Crovo - Resident Car Slut 95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 95 9C1 -Project AutoX Slut- MAB!!<--Finally!! West coast car, rust free! T56 and suspension mods to come! 94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said. American Ricerwww.badassofne.net "Ooooh! Look! Something shiny!"LOWER IT!!!  |
|  | | bammax
Posts: 2301 Join date: 2009-02-22 Age: 31 Location: Mansfield, Ma
 | Subject: Re: Bad radio signal/reception Mon Feb 08, 2010 9:12 am | |
| I'm having flashbacks The trick is to get so fed up chasing the issue and getting shocked that you say screw it and sell the car to Billy  |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
