3.08 swap to 3.42 EmptyWed Oct 19, 2022 1:27 pm by scot
3.08 swap to 3.42 EmptyTue Oct 18, 2022 8:58 pm by silverfox103
3.08 swap to 3.42 EmptyTue Sep 28, 2021 11:01 pm by silverfox103
3.08 swap to 3.42 EmptyFri Sep 24, 2021 9:53 am by ElKy
3.08 swap to 3.42 EmptySun Sep 19, 2021 6:22 pm by black blur 96
3.08 swap to 3.42 EmptySun Jun 20, 2021 11:37 am by scot
3.08 swap to 3.42 EmptyFri Jun 11, 2021 10:41 am by scot
3.08 swap to 3.42 EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
3.08 swap to 3.42 EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 3.08 swap to 3.42
5 posters
PostSubject: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 4:48 am
Help me see the light at the end of the tunnel full of bull sh$t. I'm going to be doing a rear end swap in my '96 9C1 with a set of 3.08's. I've found a '94 9C1 parts car with a rear that has 3.42's. correct me if I'm wrong, but wont I get worse gas mileage with the 3.42's? But the response from the gas peddle will be better in the city and help me forget about my wallet? I'm not sure if I should swap it in temporarally(to have the 3.08 rebuilt) or keep it in and not swap it back out once (dwindling)funds rebuild the 3.08's in the spring. Discuss...
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 6:19 am
Just swap rearends if you can. 3.42S are going to hurt fuel milage, because with them in place, you are going to be on the go pedal alot more. Go for it, or wait it out for some 3.73s.
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 6:43 am
It's a good thing my '96 isnt going to be my daily driver then, given the 3.42's. The speedo is gonna be all messed up, so my GPS will have to substitute.
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 9:23 am
Screw those wussy gears! Go 4.10's!!! Very Happy
(yeah, I know, the 3.42's are free. Wink just swap in the whole rear. Either I or a few others could fix your speedo with a lappy)
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 9:24 am
The higher the number the higher the rpm's when cruising on the highway. That makes for worse mileage and more wear on the drivetrain. For around town your mileage may not change that much since the car is getting more "off the line" ability which translates into less power needed to move from a stop.
And I'd suggest getting a tune done at some point to take full advantage of the changes being done.
And don't forget that when you swap gears out from the housing you need to swap in a new abs reluctor to match the gears. That's one reason why it's easier to swap entire rear-ends.
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 2:28 pm
Thats what I'm doing. Swapping the entire rear end. Nothing comes for free. $600 for the whole pile with an LT1(already sold)/with tranny(sold) and I had to come up with 4 wheels and tires. But I guess I will stick with the the whole swap then, and meet up with someone to program it!
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 4:02 pm
IIRC before the crash there were a few people on that other forum that went with 3.73s and city mileage improved.
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 5:03 pm
I will have to read up on some of that. My Monte Carlo SS has 3.73's, but that car gets terrible gas mileage as it is...
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySat Dec 19, 2009 8:32 pm
......you are going to be on the go pedal alot more.
Bill hit the nail on the head here^^
Around the city your going to see better mileage IF you stay off the pedal
High RPM will eat more fuel
PostSubject: Re: 3.08 swap to 3.42   3.08 swap to 3.42 EmptySun Dec 20, 2009 1:20 am
Awsesome! thanks for all the help. Learning has occured cheers cheers
3.08 swap to 3.42
» t56 swap
» T56 swap
» My L99 to LT1 swap
» Who wants to help with my swap?
» My LS swap
