 Anyone have the settings to fix ISSF?
JRS9C1
PostSubject: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 4:36 pm
I wanna get on but I can't remember what BigBadWolf said to do with the settings...
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 4:51 pm
Problems with ISSF....
I wanted to take some time and type some information to you guys.
the problem is not with ISSF, its a few global DNS servers have crashed/gone down
I have noticed quite few people from specific ISP's having issues connecting to ISSF.
here is the temp fix until the DNS servers are corrected.
in the control panel, select the network connection
right click the current network connection that your using (wireless/LAN ect...) select properties
highlight the TCP/IP internet protocol ***IF YOU HAVE SH!TSTA(vista) THEN YOU NEED TO SELECT Version 4***
Drop down to the DNS section
changed it from obtain automatically to specify the dns servers
set the primary as 4.2.2.4, and the secondary as the ip address of your router.
if you don’t know the router ip address, go to start>run>cmd
type "ipconfig"
it will display information about your network adaptors, look for the default gateway.
that is the ip address of your router.
this will resolve issues with connecting to ISSF.
JRS9C1
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 5:01 pm
Has this worked for anyone? It's not for me - go figure Mad
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 5:12 pm
Yup. Worked for me. I couldn't get it at all for a couple days at a time. No problem since I did the fix.
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 7:23 pm
I've never changed anything. I just works.
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 7:43 pm
was working earlier not now
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 8:21 pm
I'm with stupid. Razz
I did not know it had issues. scratch
PostSubject: Re: Anyone have the settings to fix ISSF?   Mon Nov 30, 2009 8:34 pm
Yeah, the past 3 weeks I couldn't get in most of the times I tried. Then when I finally DID get in, there was like 10 pages of stuff I missed! Apparently it's some big national DNS issue. BigBadWolf hooked us up with the cause and the fix. Smile
» What is up with ISSF
» NS Genelex Gold Lion KT66 owners: BEWARE!!
» 79 Impala 4-door on ISSF
» Southlands Setting
» NEED HELP WITH G.E. MODEL GD-60 WIRING
