 blower motor
PostSubject: blower motor   Wed Nov 18, 2009 10:26 am
My heater control failed to turn on the blower motor .. A few months back. I switched the blower with a known good one and still nothing. Whts next?
PostSubject: Re: blower motor   Wed Nov 18, 2009 1:35 pm
Did you try the hi setting on the fan switch ?
PostSubject: Re: blower motor   Wed Nov 18, 2009 2:52 pm
You did switch out the blower resistor pack right?
PostSubject: Re: blower motor   Wed Nov 18, 2009 5:13 pm
Exactly.
PostSubject: Re: blower motor   Sat Nov 21, 2009 5:11 pm
So Timmy. Inquiring minds want to know was is it the blower motor resistor? scratch
PostSubject: Re: blower motor   Sat Apr 03, 2010 2:06 pm
I finally decided to change the resistor. The old one was all corroded. The blower still doesn't work. I checked the fuse it was blown. I put a new one in and it blew as soon as I turned on the fan. What's next... need my AC!
PostSubject: Re: blower motor   Sat Apr 03, 2010 10:55 pm
Anybody have a clue? If it's up to me to figure out I won't have A/C for another year.
Any help is appreciated..
PostSubject: Re: blower motor   Sun Apr 04, 2010 12:43 am
I can't help but is anyone ever has a mod day just for AC repair count me in. I might even use a wrench or two. Smile
None of my cars seems to ever work. Right now the Camaro sort of works but the compressor sounds like it's going to explode and a charge only a few weeks.
PostSubject: Re: blower motor   Tue May 11, 2010 1:47 pm
my ac still dont work.... any advice will do...
PostSubject: Re: blower motor   Tue May 11, 2010 2:09 pm
If turning on the fan pops the fuse then there's a cross on the fan wire. You'll need to check the wiring to find the cross and eliminae it. It may be as simple as unplugging the resistor and the blower motor and making sure there's no corrosion in the plug itself. Also when you replaced the blower are you sure you got one with the correct amp load?
On a side thought, is the fuse the right size? I've seen plenty of cars with a fuse rated smaller or larger than what was suppossed to be in there.
PostSubject: Re: blower motor   Tue May 11, 2010 2:16 pm
The fuse is correct. I put in the blower motor from my wagon and it worked last time I used it in that car. I don't even think my blower motor was bad there is another problem. The resistor was extremely corroded.
PostSubject: Re: blower motor   Tue May 11, 2010 2:42 pm
.......... I checked the fuse it was blown. I put a new one in and it blew as soon as I turned on the fan. What's next... need my AC!
This is tough via posting
Mode switch in OFF
Blower switch LO
Fuse doesnt blow? Correct?
Pull plug from resistor pack. Confirm fuse is OK
Switch Blower switch to HI. Confirm fuse is OK. Leave switch in HI
Unplug AC pressure switch plug from accumulator
Mode switch to MAX position
If fuse blows its the blower relay or a BAD blower (which you think is OK)
If fuse doesnt blow its the resistor pack Accumulator switch or wiring
If you use a meter you could check pin to pin on the resistor pack & make sure you have resistance between all 4 pins
Important part is you dont have any dead shorts (zero resistance in this case)
In my head this method works (thats the disclaimer... Razz )
Good luck
Edited 5 efin times to try to get it right. Report back for more help Rolling Eyes
PostSubject: blower motor.   Tue May 11, 2010 3:54 pm
the same thing happened to my 87 century. every one said to replace the blower motor resistor. i did. same thing. so i replaced the blower motor relay. fixed. works excellent again. dont know if this helps or not tim. just trying to help. good luck.
PostSubject: Re: blower motor   Tue May 11, 2010 8:25 pm
See the wiring diagrams at http://ss.lencolab.com/
PostSubject: Re: blower motor   Tue May 11, 2010 8:59 pm
Is the control switch bad?
PostSubject: Re: blower motor   Wed May 12, 2010 7:16 pm
After looking over the wire diagram and reading Ron's post I suspect it may be the blower relay.
Thanks guys for your assistance, I will go through the checklist and see what's going on.
PostSubject: Re: blower motor   Thu Sep 05, 2013 1:01 am
Holy old thread but.............. I finally fixed this.. what.. 4 years later? It was a shorted wire under the hood. Relay center wire harness.
blower motor
» Need blower motor and a HVAC Control Unit for 95 RMW
» Window motor replacement
» power antenna motor problem
» Hobby King ESC and Motor
